Car type: Ruby mk 2
Can anyone suggest a supplier of rear exhaust pipe.
Austin warehouse still waiting for stock.
A near Staffordshire location would be best.
Regards
Tim
I tend to scavenge scrap piles for bits of exhaust system from which to cut tail pipes. Some run over the axle, some below. They're usually over-bore and fit over the silencer outlet, rather than slotting into it, but work perfectly well.
Car type: Ruby mk 2
Thanks Martin
I may have try that if I can’t find a supplier.
Car type:
which model is it for, Tim? I may have a NOS up and over axle rear. Can photograph on Friday...
Have you tried Mark Greening at Alderton? He certainly has, or recently had, side exit silencer/exhaust in stock. When the wriggly long tail pipe on the Ruby finally rots away or gets terminally bashed I will be putting a side exit on to replace it.
The Seven Workshop have one listed on their website.
Just curious, is this what you mean by Austin Warehouse?
Peter.
Car type: Ruby mk 2
Alderton have no stock of the up and over.
Not sure about side exit it wasn’t offered.
Sorry I meant seven workshop also no stock
