I am not thinking of changing my flywheel weight as I don't do any competition driving. However this string about modifying flywheels got my brain thinking about how light you could have a flywheel that still kept the engine ticking over. Also would an engine run without one. My limited understanding of engines tells me that it would'nt at least at low revs.
I awaite replies from member with greater automobile engineering knowledge than myself.
John Mason
There is no problem at 10 1/2 lbs,when we used to trial I used to have the tickover set at about a thousand.
I don't think you can burst a 7 flywheel as they are made from something like En 16 or greater,an alloy steel as opposed to most flywheels being made of cast iron.
As Steve has found it is possible for the centre to break out if they have been thinned near the boss.
Modern motor cycles don't have a flywheel as such and drive ok.
A counter balanced crank does not need a flywheel just some thing to mount a clutch on. Terry.
I imagine that the centre can break away because it will be stressed by the crankshaft whipping.
I'd love to Chris but you've touched on something of a mystery. For the life of me, I don't know what I did with that flywheel. I imagine I could have thrown it away but I don't tend to do that as anyone who's looked in my workshop will confirm!! However, as far as I can see, it's not about but if I ever do find it, I'd be happy to take some measurements.
01-01-2019, 07:57 AM
(This post was last modified: 01-01-2019, 08:00 AM by Bob Culver.)
1 1/4 inch is a very conservative start place for full advance at medium rpm. The advance range varies greatly depending on the distributor, wear, mods etc. if modified so full advance only at high rpm it is esp conservative.
Distributor rotor shaft can be twisted to full advance and locked there using a long screw and washer.
