Interesting manifold and carb…
(11-11-2023, 02:37 AM)David Stepney Wrote: That all sounds a bit complicated, Tony. IfI want to use Imperial measurement ('Proper Christian measurement' as my first boss would say) , I simply put a space between  the integer and the fraction thus: 1 1/8.
Indeed, a far better solution. Long live Imperial! Amusingly, I receive many requests for belts with dimensions in both metric and inch e.g. 3.2 cm wide and 4 feet long. Or, even better, "A round belt 5 mm in diameter and 30 mm long" - where the 30 mm should be 300 or even 3000 mm. Old dogs, new tricks, eh!
RE: Interesting manifold and carb… - by MartinH - 09-11-2023, 09:54 PM
RE: Interesting manifold and carb… - by Tony Griffiths - 12-11-2023, 04:12 PM
