Aluminium front backplate problems
Using cast alloy front backplates and Morris minor slave cylinders, we have an access problem.  Trying to get pipe access between one of the slave cylinders and the steering arm, is there a clever fitting for this?There doesn’t appear to be room for either the bleed nipple or the feed pipe, even using a banjo union.
Cheers,
Colin & Pete.
Cheers,
Colin.
1932 single seat special "The Moose"
Aluminium front backplate problems - by Colin McLachlan - 14-07-2021, 01:16 PM
