04-02-2018, 08:57 PM
With a big seven axle first check the radius arm fork hole are in line as you would the king pins, if that is all good you can be sure the twist is not in the centre of the axle. if the twist is in the centre just align the KP's if not then check the caster on both sides this will determine which side needs tweaking in which direction
