08-03-2021, 03:09 PM
the body isn't in a terribly low number of bits either.... have you other hobbies you are keen to keep up with too?
It is hard enough in UK for owners of part complete Nippies...
There was recently a car over here that had a saloon chassis and later Austin engine. It looks like a 65/Nippy but had been pulled together from a number of sources. If you like the shape, then that is always a possibility. It is less likely that the body is going to find a "Nippy that needs a body" over in Canada, perhaps.
Can you try and find out the stamped body number, regardless? On transmission tunnel at its nearest point to the gearbox end.
