  • 1 Vote(s) - 4 Average
Supercharged Austin seven engine advice
#40
Years ago I ran an Austin 7 special with a belt driven Shorrock C75 supercharger.  As tested on Stuart Rolts Dyno, which was accurate, it produced 32.5 bhp at 5000rpm.  The car had fabulous torque and most of the time was in top gear, probably aided by the use of 15" wheels.  Cooling was a constant problem, even with a water pump fitted.  At times there would be ice on the inlet manifold and the exhaust manifold was almost red hot.  If it idled too long it would brew up like a volcano.
I removed the blower and still have the engine.
Now I am running an Ulster rep which has a Barlow crank, light pistons, a Pigsty trials cam, standard valves,  a Ricardo head (excellent product!) and a 1 1/8" down draft SU.  It is running on 19" wheels and is every bit as powerful as the blown car, but much more practical.  It has ample torque and romps up serious hills.
If I was new to Austin 7's and I wanted a sporty model I would go for a very simple Ulster replica with an unblown engine similar to that described above.  Keep the weight down and fit a gearbox with suitable ratios.  Mine is 3 speed with a high second (the Andes box).
An Ulster can be used for almost any type of competition and can be developed into a very potent car as and when time, experience and finances allow.
RE: Supercharged Austin seven engine advice - by Malcolm Parker - 02-01-2018, 12:23 PM
