1937 Ruby spark plug colour ?
If you got your needle valve kit from Burlen, then the three washers included are all alternatives. Fitting then all will reduce the float level quite considerably.. When i overhauled my carb, I chose the washer that was closest to the one that I had removed. Not had any problems since.
To richen the tickover mixture, the little brass screw on top of the carb is screwed in - to weaken, screw it out. Don't go mad with it, it is very sensitive and the slightest turn will make a difference. try screwing yours in about 1/8th of a turn and see if the slight dip goes away. Then fiddle slightly one way or the other to get the most even tickover.
I have checked my plugs recently (nearly new D16's) and they are burning a sort of ash grey too.
1937 Ruby spark plug colour ? - by Joe eck - 20-10-2019, 07:14 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 21-10-2019, 03:07 PM
RE: 1937 Ruby spark plug colour ? - by David Stepney - 21-10-2019, 03:45 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 21-10-2019, 06:28 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 21-10-2019, 07:06 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 22-10-2019, 05:27 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 23-10-2019, 06:18 PM
RE: 1937 Ruby spark plug colour ? - by Parazine - 23-10-2019, 08:50 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 24-10-2019, 06:27 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 24-10-2019, 07:09 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 25-10-2019, 07:03 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 26-10-2019, 05:17 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 03-11-2019, 07:09 PM
RE: 1937 Ruby spark plug colour ? - by AustinWood - 04-11-2019, 12:55 PM
RE: 1937 Ruby spark plug colour ? - by Joe eck - 04-11-2019, 07:34 PM
