Timing Gears + & - Markings
Hi all, we are well and truly stuck into rebuilding an early coil bottom end. It has a 1 5/16 crank (without the oh-so-useful cutaway notches for knocking out the main bearings). The timing gears are both badly chipped and unserviceable. They are not marked with a mesh correction +/- figure and neither is the crankcase. I suspect that all the bits are original to the case ( the crank and flywheel are numbers matching). Does it pre-date meshing figures or does it mean that it is, in effect, +/- 0.00 thou?
If the latter does anyone have a good pair of zero gears available please?
All the best, Winston & Patrick Teague
Timing Gears + & - Markings - by Winston Teague - 15-10-2019, 09:17 PM
RE: Timing Gears + & - Markings - by Ian Williams - 15-10-2019, 09:46 PM
