  • 2 Vote(s) - 3 Average
Noisy gearboxes
I have got a couple of gearboxes that I think have the same problem - they are both noisy, particularly noticeable when the engine is idling and the gearbox in neutral. The noise disappears if the clutch is pressed. Both gearboxes are 4 speed 2 syn with Nippy close ratio gears, one original and the other modified to close ratio.
The gearboxes have shown the same symptoms on two different engines so I don't think the problem is engine or flywheel related.  The only things turning in the gearbox when in neutral are the first motion shaft and the lay-shaft. The first motion shaft and inter-shaft bearings are both in good condition so I am thinking it must be related to the lay-shaft.
I have measured the lay-shaft end float on one box as 20 thou which is a lot more than recommended but the lay-shaft bearings look in reasonable condition. Could the end float be the cause of the noise or is there something else that I should be looking at?
I have an MPEG 4 audio file of the noise - does anyone know if it is possible to upload it here?
Noisy gearboxes - by daveg - 27-09-2019, 05:47 PM
RE: Noisy gearboxes - by Chris KC - 27-09-2019, 06:10 PM
RE: Noisy gearboxes - by daveg - 27-09-2019, 07:34 PM
RE: Noisy gearboxes - by Mike Costigan - 27-09-2019, 09:04 PM
RE: Noisy gearboxes - by Ian Williams - 27-09-2019, 09:22 PM
RE: Noisy gearboxes - by daveg - 27-09-2019, 10:49 PM
RE: Noisy gearboxes - by Tony Betts - 28-09-2019, 02:18 AM
RE: Noisy gearboxes - by Bob Culver - 28-09-2019, 05:43 AM
RE: Noisy gearboxes - by Chris KC - 28-09-2019, 08:46 AM
RE: Noisy gearboxes - by daveg - 28-09-2019, 10:44 AM
RE: Noisy gearboxes - by Tony Betts - 28-09-2019, 02:20 PM
RE: Noisy gearboxes - by Chris KC - 28-09-2019, 07:28 PM
RE: Noisy gearboxes - by Peter Naulls - 28-09-2019, 09:22 PM
RE: Noisy gearboxes - by daveg - 28-09-2019, 11:35 PM
RE: Noisy gearboxes - by Tony Betts - 29-09-2019, 01:57 AM
RE: Noisy gearboxes - by Ian Williams - 29-09-2019, 08:59 PM
RE: Noisy gearboxes - by Hedd_Jones - 30-09-2019, 07:06 AM
RE: Noisy gearboxes - by Ian Williams - 30-09-2019, 07:43 AM
RE: Noisy gearboxes - by daveg - 30-09-2019, 10:38 AM
RE: Noisy gearboxes - by Chris KC - 30-09-2019, 11:54 AM
RE: Noisy gearboxes - by Dave Mann - 30-09-2019, 03:18 PM
RE: Noisy gearboxes - by bob46320 - 30-09-2019, 04:24 PM
RE: Noisy gearboxes - by Dave Mann - 30-09-2019, 07:35 PM
RE: Noisy gearboxes - by Reckless Rat - 30-09-2019, 07:41 PM
RE: Noisy gearboxes - by Ian Williams - 30-09-2019, 08:03 PM
RE: Noisy gearboxes - by daveg - 30-09-2019, 08:42 PM
RE: Noisy gearboxes - by Ian Williams - 30-09-2019, 09:03 PM
RE: Noisy gearboxes - by daveg - 01-10-2019, 07:38 PM
RE: Noisy gearboxes - by Ian Williams - 01-10-2019, 08:46 PM
RE: Noisy gearboxes - by Bob Culver - 01-10-2019, 11:32 PM
RE: Noisy gearboxes - by Terrytuned - 02-10-2019, 12:15 AM
RE: Noisy gearboxes - by daveg - 02-10-2019, 08:57 PM
RE: Noisy gearboxes - by Bob Culver - 02-10-2019, 09:44 PM
RE: Noisy gearboxes - by Ian Williams - 02-10-2019, 10:15 PM
RE: Noisy gearboxes - by daveg - 31-03-2022, 08:01 PM
