The Joss Campbell Special
#22
(05-06-2019, 09:01 AM)Ian Williams Wrote: Well Tony the spring is completely flat and there is no load on it yet and as I am sure you are aware they settle after being reset, it may end up with less leaves once the car is complete, so just a starting point at present. I had to make a spring wedge to get the castor sensible but thats not unusual, I will post some pictures of how we have stiffened the nose, my car is the same but with a whole lot more complication elsewhere!
Ian would you be able to provide some details regarding how you have adjusted the castor and immobilised one spring shakle on the Nippy axle? I presume you also dropped the radius arm mounting ball as well as the spring wedge.
Many thanks in anticipation.
Bruce
The Joss Campbell Special - by Ian Williams - 05-06-2019, 05:45 AM
RE: The Joss Campbell Special - by JonE - 05-06-2019, 08:08 AM
RE: The Joss Campbell Special - by Howard Wright - 05-06-2019, 08:37 AM
RE: The Joss Campbell Special - by Tony Betts - 05-06-2019, 08:39 AM
RE: The Joss Campbell Special - by Ian Williams - 05-06-2019, 09:01 AM
RE: The Joss Campbell Special - by Marcus Ling - 05-06-2019, 09:42 PM
RE: The Joss Campbell Special - by Ian Williams - 05-06-2019, 11:44 PM
RE: The Joss Campbell Special - by DavidL - 06-06-2019, 12:14 AM
RE: The Joss Campbell Special - by Jeff Taylor - 06-06-2019, 01:25 AM
RE: The Joss Campbell Special - by Ian Williams - 06-06-2019, 06:53 AM
RE: The Joss Campbell Special - by DavidL - 06-06-2019, 09:41 AM
RE: The Joss Campbell Special - by Ian Williams - 06-06-2019, 10:23 AM
RE: The Joss Campbell Special - by Ian Williams - 06-06-2019, 09:31 PM
RE: The Joss Campbell Special - by Marcus Ling - 22-06-2019, 03:17 AM
RE: The Joss Campbell Special - by Ian Williams - 22-06-2019, 08:42 AM
RE: The Joss Campbell Special - by Ian Williams - 22-06-2019, 10:28 AM
RE: The Joss Campbell Special - by Alan - 22-06-2019, 11:20 AM
RE: The Joss Campbell Special - by Andrew Wilson - 22-06-2019, 12:58 PM
RE: The Joss Campbell Special - by wild_willy - 22-06-2019, 01:59 PM
RE: The Joss Campbell Special - by Terrytuned - 22-06-2019, 06:11 PM
RE: The Joss Campbell Special - by Ian Williams - 22-06-2019, 09:40 PM
RE: The Joss Campbell Special - by wild_willy - 23-06-2019, 06:09 AM
RE: The Joss Campbell Special - by JonE - 23-06-2019, 07:07 PM
RE: The Joss Campbell Special - by Ian Williams - 23-06-2019, 09:11 PM
RE: The Joss Campbell Special - by squeak - 23-06-2019, 11:38 PM
RE: The Joss Campbell Special - by Tony Press - 24-06-2019, 12:32 AM
RE: The Joss Campbell Special - by squeak - 24-06-2019, 02:10 AM
RE: The Joss Campbell Special - by Ian Williams - 24-06-2019, 06:18 AM
RE: The Joss Campbell Special - by Howard Wright - 24-06-2019, 08:53 AM
RE: The Joss Campbell Special - by AustinWood - 24-06-2019, 11:49 AM
RE: The Joss Campbell Special - by Zetomagneto - 24-06-2019, 09:59 PM
RE: The Joss Campbell Special - by Howard Wright - 25-06-2019, 09:17 AM
RE: The Joss Campbell Special - by AustinWood - 26-06-2019, 08:20 AM
RE: The Joss Campbell Special - by Ian Williams - 03-07-2019, 06:19 AM
RE: The Joss Campbell Special - by Ian Williams - 03-07-2019, 10:37 PM
