17-06-2019, 09:19 PM
(This post was last modified: 17-06-2019, 09:21 PM by Ruairidh Dunford.)
The oil pressure should go off the gauge when cold Bill - it will come down to around 3lbs or so after being warmed up fully.
You may have a faulty gauge or you may have fitted the oil pump vanes upside down - the chamfered ends go to the top of the engine.
Try another gauge if you can, initially. I can send you one that I know works, if that helps.
