13-06-2019, 10:51 PM
Hi All,
Just to clarify a few points.
The chassis mounts on the original beam axle from austin were a straight pin bolted to the Chassis and a bushed end on the Radius rod not a Spherical rod end, movement was catered for at the connection with Axle.
Any rotational movement of the Beam( MUST )take place Between the points on the beam where the rods are attached, only one rotational joint is required,Reason being it is the rods that cause the twist
The design of the joint is open to your own interpretation
Colin
NZ
Colin
NZ
