  • 1 Vote(s) - 5 Average
Newman cam profiles
(15-03-2019, 11:49 AM)Terrytuned Wrote: A new Newman 70-30 cam you have to fit the centre bearing as an assembly as the cam peaks will not go through the cam ring when it is fitted to the crankcase.  Terry.
Terry
Is that a cam with a 318 lift, as per the original post , or does the 70-30 cam that you mention have a higher lift?
I know that a 375 lift Nippy won't fit but I have a seen a 330 inlet lift cam fit.
Thanks
Charles
Newman cam profiles - by Dirk73 - 14-03-2019, 12:12 PM
RE: Newman cam profiles - by Speedex750 - 14-03-2019, 01:29 PM
RE: Newman cam profiles - by Dirk73 - 14-03-2019, 06:42 PM
RE: Newman cam profiles - by Colin Reed - 14-03-2019, 08:30 PM
RE: Newman cam profiles - by Boaty - 14-03-2019, 10:58 PM
RE: Newman cam profiles - by Bob Culver - 15-03-2019, 12:16 AM
RE: Newman cam profiles - by Stuart Giles - 15-03-2019, 09:40 AM
RE: Newman cam profiles - by Alan - 15-03-2019, 11:18 AM
RE: Newman cam profiles - by Terrytuned - 15-03-2019, 11:49 AM
RE: Newman cam profiles - by Boaty - 15-03-2019, 12:42 PM
RE: Newman cam profiles - by Charles P - 15-03-2019, 04:20 PM
RE: Newman cam profiles - by Terrytuned - 15-03-2019, 07:02 PM
RE: Newman cam profiles - by Charles P - 15-03-2019, 07:22 PM
RE: Newman cam profiles - by Zetomagneto - 15-03-2019, 08:17 PM
RE: Newman cam profiles - by Dirk73 - 15-03-2019, 10:19 PM
RE: Newman cam profiles - by Terrytuned - 16-03-2019, 08:45 PM
