(25-01-2019, 10:45 AM)rubyman Wrote: Just what I wanted to know, I take it its the same for Ruby mk2, my petrol gauge is not working I have checked the gauge which test's out ok and live feed & earth at the gauge, so I am going to drop the tank to check the sender & wiring, unless anyone knows a better way.
Thanks for all replies
Graham in Sheffield
Have you lifted the rear passenger seat? I found a hole just above the fuel sender unit on my Ruby Mk 1, very easy access to the fuel sender.
(24-01-2019, 10:13 PM)Nigel Ricardo Wrote: You should have 2 nuts on a U bolt on the side of the tank under the car, between the tank ( end of the tank ) and the inner wheel arch
Thanks for the info Nigel.
(25-01-2019, 03:21 PM)Bob Kneale Wrote:(25-01-2019, 10:45 AM)rubyman Wrote: Just what I wanted to know, I take it its the same for Ruby mk2, my petrol gauge is not working I have checked the gauge which test's out ok and live feed & earth at the gauge, so I am going to drop the tank to check the sender & wiring, unless anyone knows a better way.
Graham in Sheffield
Although this thread is primarily concerned with the mechanics of physically removing the tank, a number of relevant electrical issues have crept in!. I suspect by now you have succeeded in removing the petrol tank, by attacking the 'U' bolt fixings. When you come to putting it back, its a good idea to run a separate earth wire between the sender unit to the earth connection on the back of the petrol gauge. It's very often not the gauge or the sender at fault, but the appallingly bad earth return path that relies on the bodywork/chassis to act as a conductor. The 'genius' who came up with that money saving concept should have been pubicly flogged years ago!
Remember the petrol gauge is not a simple rheostat (as we were probably taught at school) - there is another coil involved.
Good luck with the tank removal etc. you'll find it more dirty than difficult.
Bob
Thanks for the info Bob. Haven't got round to battling again with the Ruby fuel tank. The family are keeping me out of the garage at the moment, I would live in there if I was allowed.
Cheers,
Darren
(25-01-2019, 01:27 AM)Jeff Taylor Wrote: Is it not possible to use a nut splitter on the four U bolt nuts ? This would leave your U bolt threads undamaged ready for the U bolts be cleaned up and needing only four new nuts and spring washers to finish the job.
To be honest Jeff I haven't tried them yet. I'll purchase a set and try them before getting the Dremel out. Thanks for the advice.
