(16-01-2019, 10:41 AM)JonE Wrote: Was reading about the removal of one edge of the block around each bore to enable transition of top of piston area into valve area on the later and sports heads. It doesn't give details of depth you take away, but presumably even a mm or so would be effective.
Is this still something any of you do? Or is it seen as damaging blocks which might be re-used for LC where it wouldn't be useful?
Hi Jon,
Just reading this tread for the first time. A good place to look for info on this is the H.A.M.B. JallopyJournal forum. being American there is lots of discussion re modding 'flatheads'.
Paul
(18-01-2019, 01:17 PM)Paul N-M Wrote:Also should have mentioned the Hot Rod Network especially the 'Truth about Ford flatheads, myths exposed' article.(16-01-2019, 10:41 AM)JonE Wrote: Was reading about the removal of one edge of the block around each bore to enable transition of top of piston area into valve area on the later and sports heads. It doesn't give details of depth you take away, but presumably even a mm or so would be effective.
Hi Jon,
Paul
All very interesting.
Paul
