19-12-2018, 05:55 PM
(18-12-2018, 02:02 PM)Chris KC Wrote:(18-12-2018, 12:00 PM)Dave Mann Wrote: I stand the cleaned crankcase with oil pump installed in a clean tray with some clean paraffin in it and drive the oil pump with a socket (mounted in my electric drill) on the oil pump drive gear nut. Oh and the front camshaft bearing is positioned to blank off the oil hole. All of the crankcase plugs are loose and removed one at a time to flush any dirt out and it's surprising how much dirt appears in the bottom of the tray from a crankcase I had cleaned. I usually change the paraffin for a second go. Wellington boots are optional extra PPC.
In all seriousness, anyone who saw me hobbling about with a stick a couple of years ago at Beaulieu may be shocked to learn it was the result of getting my left sock splashed with paraffin. I was 'busy' at the time so ignored it for an hour or two. My foot inflated like a ruddy melon. Have been dunking stuff in paraffin since time began so don't know if I got some 'bad' stuff or perhaps have become sensitised after all these years.
This sounds like a good approach to me (I don't use splash feed!) but it makes me wonder all the more about how the heck the big ends get lubricated at all on a cold morning start (in which condition oil ain't nearly so runny as paraffin).
Another thing to consider when uprating oil pumps is the rating of your pressure relief valve spring - easily forgotten component!
One of the old timers taught me to turn the engine over by hand for a count of 12 (6 turns) as the first operation when starting up a cold engine on a cold day. Presumably this was to circulate some oil - hopefully it would get as far as the big ends?
Colin
