Oil tight Austin Seven?
#51
(09-10-2018, 09:25 PM)Zetomagneto Wrote:
(09-10-2018, 10:08 AM)JonE Wrote: well, trying to be as optimistic as possible, at least he didn't do it on an even earlier, rarer car.
At least the body is staying with the car, which is not something which can always be said with ulsteroids...
Why is there so much fuss, it’s only an RP , there are plenty around but perhaps only one electric.
It appears to have made available lots of parts for others.It has an owner, and it is his car to do as he wishes.
At some later stage this if it is offered for sale it can be returned to standard.
Nobody seams to make such a fuss when an alternative petrol engine is fitted.
(10-10-2018, 11:08 AM)JonE Wrote: Yes, let's face it, there are going to be a hell of lot of dusty Austin 7s waiting for a few hundred years until the remaining humanoid planet dwellers come back to sufficient numbers to be bothered to want to drive somewhere. Time to sell up if you live near the beach...
They'll be in demand Jon when none of the modern stuff works any more!
Oil tight Austin Seven? - by Ruairidh Dunford - 05-10-2018, 08:11 AM
RE: Oil tight Austin Seven? - by Jamie - 05-10-2018, 08:58 AM
RE: Oil tight Austin Seven? - by morrisminor - 05-10-2018, 09:11 AM
RE: Oil tight Austin Seven? - by JonE - 05-10-2018, 09:16 AM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 09:31 AM
RE: Oil tight Austin Seven? - by Martin Prior - 05-10-2018, 10:49 AM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 08:17 PM
RE: Oil tight Austin Seven? - by Chris KC - 09-10-2018, 08:28 PM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 08:46 PM
RE: Oil tight Austin Seven? - by Duncan Logan - 10-10-2018, 07:52 AM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 10:23 AM
RE: Oil tight Austin Seven? - by Dave Mann - 05-10-2018, 10:14 AM
RE: Oil tight Austin Seven? - by Martin Prior - 05-10-2018, 10:44 AM
RE: Oil tight Austin Seven? - by Simon Scott - 05-10-2018, 10:45 AM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 10:58 AM
RE: Oil tight Austin Seven? - by Hedd_Jones - 05-10-2018, 12:19 PM
RE: Oil tight Austin Seven? - by Ian Dunford - 05-10-2018, 04:05 PM
RE: Oil tight Austin Seven? - by Austin Carr - 05-10-2018, 04:31 PM
RE: Oil tight Austin Seven? - by Hedd_Jones - 05-10-2018, 04:52 PM
RE: Oil tight Austin Seven? - by John Mason - 05-10-2018, 04:56 PM
RE: Oil tight Austin Seven? - by Chris KC - 05-10-2018, 05:21 PM
RE: Oil tight Austin Seven? - by Dave Mann - 05-10-2018, 05:42 PM
RE: Oil tight Austin Seven? - by spannerman - 05-10-2018, 05:54 PM
RE: Oil tight Austin Seven? - by Ian Williams - 05-10-2018, 08:46 PM
RE: Oil tight Austin Seven? - by Bob Culver - 06-10-2018, 07:58 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 06-10-2018, 08:38 AM
RE: Oil tight Austin Seven? - by Mark McKibbin - 08-10-2018, 11:49 AM
RE: Oil tight Austin Seven? - by Dave Mann - 06-10-2018, 09:29 AM
RE: Oil tight Austin Seven? - by Chris KC - 06-10-2018, 10:21 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 06-10-2018, 11:04 AM
RE: Oil tight Austin Seven? - by Dave Mann - 07-10-2018, 08:57 AM
RE: Oil tight Austin Seven? - by Chris KC - 07-10-2018, 02:43 PM
RE: Oil tight Austin Seven? - by Colin Morgan - 07-10-2018, 10:36 AM
RE: Oil tight Austin Seven? - by Dave Mann - 07-10-2018, 02:51 PM
RE: Oil tight Austin Seven? - by Colin Wilks - 07-10-2018, 04:20 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 08-10-2018, 12:30 PM
RE: Oil tight Austin Seven? - by Martin Prior - 09-10-2018, 09:31 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 08-10-2018, 02:13 PM
RE: Oil tight Austin Seven? - by JonE - 09-10-2018, 10:08 AM
RE: Oil tight Austin Seven? - by Zetomagneto - 09-10-2018, 09:25 PM
RE: Oil tight Austin Seven? - by DazeOff - 09-10-2018, 03:31 PM
RE: Oil tight Austin Seven? - by Martin Prior - 09-10-2018, 03:56 PM
RE: Oil tight Austin Seven? - by JonE - 09-10-2018, 03:57 PM
RE: Oil tight Austin Seven? - by Ian Williams - 09-10-2018, 08:09 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 09-10-2018, 09:43 PM
RE: Oil tight Austin Seven? - by Tony Press - 10-10-2018, 05:29 AM
RE: Oil tight Austin Seven? - by JonE - 10-10-2018, 11:08 AM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 11:37 AM
RE: Oil tight Austin Seven? - by Biddlecombe - 10-10-2018, 11:35 AM
RE: Oil tight Austin Seven? - by Dave Wortley - 10-10-2018, 03:09 PM
RE: Oil tight Austin Seven? - by John Mason - 10-10-2018, 04:25 PM
RE: Oil tight Austin Seven? - by jansens - 10-10-2018, 07:45 PM
RE: Oil tight Austin Seven? - by Chris KC - 10-10-2018, 08:04 PM
RE: Oil tight Austin Seven? - by Tony Press - 11-10-2018, 01:38 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 07:06 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 07:44 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:08 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 08:25 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 08:27 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:38 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 08:42 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 09:28 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 08:54 AM
RE: Oil tight Austin Seven? - by stuartu - 11-10-2018, 08:55 AM
RE: Oil tight Austin Seven? - by Dave Mann - 11-10-2018, 09:56 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:11 AM
RE: Oil tight Austin Seven? - by Terry McGrath - 11-10-2018, 10:13 AM
RE: Oil tight Austin Seven? - by squeak - 11-10-2018, 12:27 PM
RE: Oil tight Austin Seven? - by Annaustin - 13-10-2018, 11:05 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:12 AM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:18 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:36 AM
RE: Oil tight Austin Seven? - by Tony Press - 11-10-2018, 10:57 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 11-10-2018, 09:39 AM
RE: Oil tight Austin Seven? - by jansens - 11-10-2018, 09:51 AM
RE: Oil tight Austin Seven? - by Hedd_Jones - 11-10-2018, 10:07 AM
RE: Oil tight Austin Seven? - by Chris KC - 11-10-2018, 02:43 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 12-10-2018, 08:26 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 12-10-2018, 10:34 PM
RE: Oil tight Austin Seven? - by squeak - 13-10-2018, 02:39 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 13-10-2018, 09:02 AM
RE: Oil tight Austin Seven? - by DazeOff - 14-10-2018, 07:19 PM
RE: Oil tight Austin Seven? - by JonE - 13-10-2018, 03:59 PM
RE: Oil tight Austin Seven? - by Tony Press - 13-10-2018, 09:49 PM
RE: Oil tight Austin Seven? - by Duncan Logan - 15-10-2018, 05:46 AM
RE: Oil tight Austin Seven? - by squeak - 13-10-2018, 11:15 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 14-10-2018, 08:22 PM
RE: Oil tight Austin Seven? - by Tony Press - 14-10-2018, 10:19 PM
RE: Oil tight Austin Seven? - by Ian Williams - 14-10-2018, 08:27 PM
RE: Oil tight Austin Seven? - by Viteran - 14-10-2018, 10:46 PM
RE: Oil tight Austin Seven? - by Bob Culver - 15-10-2018, 07:16 AM
RE: Oil tight Austin Seven? - by Ian Williams - 15-10-2018, 09:40 AM
RE: Oil tight Austin Seven? - by merlinart - 15-10-2018, 02:14 PM
RE: Oil tight Austin Seven? - by Tony Press - 15-10-2018, 10:06 PM
RE: Oil tight Austin Seven? - by Ruairidh Dunford - 15-10-2018, 09:45 AM
RE: Oil tight Austin Seven? - by Colin Morgan - 15-10-2018, 11:43 AM
RE: Oil tight Austin Seven? - by Martin Prior - 15-10-2018, 12:16 PM
RE: Oil tight Austin Seven? - by Ray White - 15-10-2018, 02:05 PM
RE: Oil tight Austin Seven? - by vintage_racing - 16-10-2018, 10:02 AM
RE: Oil tight Austin Seven? - by Dave Prior - 16-10-2018, 10:15 AM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 10:32 AM
RE: Oil tight Austin Seven? - by DazeOff - 16-10-2018, 08:10 PM
RE: Oil tight Austin Seven? - by Ray White - 16-10-2018, 11:48 AM
RE: Oil tight Austin Seven? - by John Mason - 16-10-2018, 12:29 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 16-10-2018, 12:56 PM
RE: Oil tight Austin Seven? - by DazeOff - 16-10-2018, 07:27 PM
RE: Oil tight Austin Seven? - by Ian Williams - 16-10-2018, 08:10 PM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 08:40 PM
RE: Oil tight Austin Seven? - by Ray White - 16-10-2018, 08:50 PM
RE: Oil tight Austin Seven? - by Martin Prior - 16-10-2018, 09:24 PM
RE: Oil tight Austin Seven? - by Reckless Rat - 16-10-2018, 09:37 PM
RE: Oil tight Austin Seven? - by Zetomagneto - 16-10-2018, 10:06 PM
RE: Oil tight Austin Seven? - by Tony Press - 16-10-2018, 11:57 PM
