Not really Rivet Counting!
Getting to the stage of reassembling wings etc for a trial "fit" on the AG tourer and I wonder which way are the bolts inserted?
When dis-assembled there were bolt heads on the outside looking in & on the inside looking out! Totally (apparently) random! Quite apart from many being metric roofing bolts!
To my mind the logic would be to have the heads outside so any  threads sticking out beyond the nut was not exposed to the elements, BUT for rear wings would the bolt length into the rear passenger area foul the wheel arch trim (ply & rexine) or whatever?
As an aside: I think a little thought on the part of Mr Edge or later minions could have made life much easier to remove the radiator etc without having to undo / remove everything in sight! Perhaps there is a sequence that evades me, or maybe my radiator is, along with the gearbox/engine mountings/not the original.....
Not really Rivet Counting! - by David.H - 28-09-2018, 07:58 AM
RE: Not really Rivet Counting! - by David.H - 28-09-2018, 12:34 PM
RE: Not really Rivet Counting! - by spannerman - 28-09-2018, 05:11 PM
