Clutch Levers Position - Clutch not releasing
#22
(17-08-2018, 08:10 PM)stuartu Wrote: "Do you know if the Thrust Bearing is supposed to be permanently connected?"
If you are using a three speed thrust bearing in a carrier with slots for the toggle levers self evidently it is permanently engaged. If a four speed thrust bearing, no.
Which are you using?
Regards,
Stuart
Thanks Stuart. Ours is a 4 speed and the thrust bearing has no slots. Will make sure it's adjusted appropriately!
RE: Clutch Levers Position - Clutch not releasing - by Eddamoo - 19-08-2018, 03:22 PM
