29-07-2018, 01:39 AM
Thanks Dave for your response but the C35A front housing is a bit different as Bob has explained in his response. Bob I haven't found much on the C35M on the internet. I'm aware that they were used on other vehicles but with very little documentation. It appears that the bearing is held between the 2 housings and then there is a space between the bearing and the felt seal. In my case this leaves a flat washer and a stepped spacer which assembly order or function aren't obvious. It could also be missing parts as well as the generator in question was only loosley assembled when I got it.
Are you able to scan your sketches and post and/or confirm where the stepped spacer goes? I will take some pics on the asembley laid out in the order I think it should be.
Many thanks
Bruce
Many thanks
Bruce
