Hi All,
I have several nut plates (2BA) riveted to the bulkhead of my Ulster Rep. They are used to hold down the panel at the starter. Does anyone have a source for these in 2BA as well as 1/4 Whitworth?
Erich in Seattle
Erich - I found 2ba rivnuts from a company in Northern Ireland but had to buy 2000 at a time - I went for Metric ones in the end and used older looking nickel plated screws which suit this fixing very well.
I can post Chris some to bring to you, if you only need a couple.
Thank you all. Stuart, those are good sites. As no supplier seems to have 1/4 Whitworth(no surprise) would anyone know what I could get away with in terms of drilling and tapping for 1/4 Whitworth? I was thinking No. 10 would still leave enough meat in the nut. These are only going to be used at the rear of the side panels so won't carry much of a load. I'll likely use the solid ones rather than the caged ones and attach with solid rivets.
Erich in Seattle
