Hi All
I’ve started to clean up a 1931/2 diff banjo as I hope to pick up a suitable torque tube on Sunday.
I’ve found this welding. The only reason I can think of for doing this is that the casting was porous in this area. Anyone else seen this?
Definitely seen signs of welding in that area before - why, I don't know.
I've seen that on a few RN diff cases.
Am not familiar with those cases. Could a carbon arc have been used to heat for bearing entry?
Hi All
Thanks for the comments which show that my banjo isn’t the oddity I thought it was. Bob..on this axle the bearing is fixed in the torque tube which needs to be a sliding fit in the banjo to allow for adjustment in the mesh of the CW&P.
