Car type: Austin 7 Tourer AG 1931
I have a 1931 tourer, the ammeter and switches are early type, located in the centre of the dashboard. The ammeter has always read in reverse, the ignition light has never worked, the car is positive earth. The dynamo and cutout are both working, the dynamo has been changed to a two brush set up. I have reversed the terminals at the back of the meter, but the car won't start, it runs when changed back.
please could you advise a solution. thank you.
Morning Chris, reversing the wires on the ammeter should work (and the engine should run) I would suspect a break in one of the wires going to the ammeter which makes a circuit when bent in a particular position.
Thanks for the info. Chris
Compared with the diagrams for moderns this is a joy to behold. Neverthelss none of the common variants make the workings abundantly clear. I am sure if someone with access to a switch could redraw and expand it would prove useful esp for those with minimal electrical experience. I presume it is possible to select headlamps and summer charge together? The form of the wiper(s) in the ign/charge switch are not obvious
A bit dangerous me commenting on electrics, but.... Wipers were mostly vacuum on early cars I think, so no need to show them, if fitted as a
modern upgrade then use the A(ccessories) terminal or the fuse box perhaps?
