I'm 30 years out of date on Austin 7s but my godson has a front axle with this issue. What are the options? I've heard of forging them back to standard, sleeves, over size pins. I've also heard of racing cars with pins made of different material. How much of the chit chat is sensible and doable?
David
Various oversize kingpin sizes are available. I got a set from David Cochrane and used an adjustable reamer to open the axle and bearings to the correct size.
Ray
Car type: 1932 RN saloon
I don't think sleeving is safe. The axle eye area hasn't enough metal round it. Ian Dunford might still be repairing axle eyes and other axle repair magic.
Loose eyes have been a Seven attribute forever, esp here where many roads were endlessly corrugated metal.
With the pre Girling stubs oversize kingpins are inconvenient as a blind reamer is required.
The time honoured method for Sevens is to red heat the eye and forge smaller. The metallurgical aspects are dubious especially on the nth repeat. May contribute to cracking often evident where the H section begins. However sure to have been done at some time.
For other makes for modest stretch a bead of weld is used to shrink. Despite room for much more metal the eyes are very small for the later heavy cars. A general reinforcing with weld seems prudent.
(In NZ, despite the improved safety, welding is not allowed for 6 monthly w.o.f so has to be disguised)
Happy as ever to show my ignorance. How does welding the outside of the eye shrink it? Does the heat of the welding expand the metal in such a direction that the eye reduces in diameter? Or am I barking up the completely wrong tree?
Jamie.
One of the first things you discover when arc welding is the surprising distorton which occurs on cooling. The contracting metal exerts a very strong force. If a bead is laid along a heavy strip it will curl the strip toward the bead. At least with larger kingpins not too loose, a bead around the eye is sufficent to contract the heat softened eye. (For quality repairs of general engineering items successive beads were often peened after to expand the metal and reduce distortion and locked up stress)
Thank you for the explanations: it makes total sense, now. I have encountered warping and bending when welding sheet metal enough in the past that I should have realised how the shrinking would work.
Jamie.
