Car type: 1929 AD Tourer, 1930 Rosengart LR2, Rosengart LR4 Van 1938 APE Tourer (Opal)
06-11-2018, 05:23 PM
(This post was last modified: 06-11-2018, 05:26 PM by Derek Sheldon.)
Having struggled for years getting all of the springs and bits in alignment I came up with what I believe to be an ingenious idea, ( now tell me it’s not original).
Using the alignment tool as described in Woodrows and a Jubilee clip. See pictures
Clamp the assembly and compress, drop the Jubilee clip over the splines and tighten. I then use three long set screws and nuts to hold the whole thing together whilst finaly centralising the spline and tightening the six fixing bolts.
I didn't have difficulty by aligning the clutch using 2 of the crank case studs.. Ie a flat bar (like yours) and locate that on the 2 studs. If you are taking the engine from and existing setup, check your bar against the clutch output shaft before you take it to pieces.
06-11-2018, 06:37 PM
(This post was last modified: 06-11-2018, 07:28 PM by Derek Sheldon.)
Bob, you miss my point. It’s getting the springs etc in the correct places in the verticle
. Once the springs are slightly compressed and held in place, then use the bar to align.
Car type: 1932 RN saloon
Never used a clutch centring tool. Always seems to fit without it. Good plan though Derek.
Cheers,
Dave.
Derek's photos show the tool fitted to his Rosengart engine - this would appear to be a good idea for Austin three speed clutches, thanks for sharing!
Charles
No such thing on a Rosengart, the toggles are pre-engaged see picture
