Thanks Ruairidh. I was thinking that the needs for jointing the block to crankcase and the crankcase to sump are somewhat different, the sump needing to come off regularly, but the block to crankcase joint benefiting from every bit of rigidity that can be mustered, and hopefully not requiring disassembly very often. I am planning a rebuild this winter and thinking that silicone sheet for the sump, but TB1184 for the block/crankcase joint may be the way to go.
Sounds good although I have also found the silicon block gasket pretty bullet proof, I've fitted about 30 of them now and really like them.
When remembering the typical Seven of the 60s the workmanship lavished on many today brings a smile. The original engine in my car was dismantled umpteen times by my father and a few by myself yet all threads remain original. Other engines acquired later were a jumble of threads. Persons learn by experience and many learned on a Seven. Fastener tensions are very different from modern Jap cars!
My father used to joke that the sump rusted. Home made cork gaskets were used but care necessary to avoid chips inside. (I have never purchased a sump gasket for any of my family cars!) If not glued can often reuse. Any threads which break into fluid need a fibre washer under the bolt head.
Car type: '27 Chummy, '34 Special, '50 Traction Avant
I have noticed advertised on Ebay, silicone valve chest gaskets. Has anyone tried them?
Mark
Do stop leak oil additives do any good?
Thank you all for your comments and input.
Everyone generally has their own favored methods of doing things or resolving issues with their particular application. I've seen a lot of sumps on BMC cars with shallow depressions around where the bolts hold the pressed metal sump to the cast block resulting in leaks generally between the bolts. This is from repeated over tightening in order to get a leak proof seal. I reasoned that if there was a thick metal retainer around the edge the compression would be much more even and consistent resulting in no leaks or at least minimal ones.
I guess time will tell once its all together.
Stephen
Steve I can tell you that your Idea works, I have done the same myself in the past. I can also concur that silicone baking sheet gaskets are successful, as is Loctite 518 and paper. Unless your sump is horribly distorted most leaks appear to be oil coming through open bolt threads than past the gasket. Alan Raeburn used to produce an alloy sump that was chamfered at the front, these were/are excellent, slightly deeper than std, stiffening baffles and the chamfer makes engine removal a breeze, not sure if they are currently supplied by anyone in the UK.
