07-02-2019, 12:10 PM
(This post was last modified: 07-02-2019, 12:10 PM by AllAlloyCup.)
As ever Jim gives wise advice to the needy!
Regards
Bill G
Regards
Bill G
Uncoupled car Handbrake Details.
Regards Bill G
11-02-2019, 11:01 PM
This picture shows the bracket that has been fitted to ky chassis to mount the front of the ratchet on. Rather than the lug on the gearbox. It fits on the front of the crossmember.
Plan is now to temporarily refit to compare measurements. Adjust as neccassary and make a stop to the requisite dims and I should be good to go
12-02-2019, 03:43 AM
(11-02-2019, 11:01 PM)Hedd_Jones Wrote: This picture shows the bracket that has been fitted to ky chassis to mount the front of the ratchet on. Rather than the lug on the gearbox. It fits on the front of the crossmember. Hedd it's worth noting that the original setup has the ratchet RESTING on the top bolt fixing of the handbrake lever. This keeps it in contact with the pawl, not obvious in your picture. cheers Russell
13-02-2019, 06:38 PM
here is a photo if the bracket bolted to the chassis and on the car. It looks near enough to me. Just a stop to make then.
