Car type: 1934 RP Saloon
Howard.. Sadly I no longer have this wedge. It was donated to a special build some 30+ years ago and I have no idea what has become of the car. However in principal it should be fairly easy to produce something along those lines.
Thanks Bruce
My own solution has been to add a very small wedge to the front of the steering box plate and shave a small amount off the back. I've managed to get about 4 degrees extra inclination on the column without altering the position of the brake pivot which is fine for me as I started with a 41 degree steering box.
