Car type:
Thanks Jeff. I've also just spoken to Burlen who suggest that there is no difference in operation of the two jet types. So I should just go with whatever is on my present linkage - the (slightly more expensive) eyebolt one.
I wondered what the extra drilled 'oles might do in practice...
Car type:
thanks Jeff - brought them home from garage today but now I'm working away for a few days so will photo when back. I won't order from Burlen until after then anyway... their postage is so exorbitant for small packages I don't want to miss anything out! (Need to find the right brass damper cap too)
Sorry to give a different slant to this topic but I have an SU carb on a high compression headed in a 19 29 fabric bodied saloonwhich floods badly to the point of causing the engine to stop. Once it sits for a while it starts again but floods to a stop again. There is no spring or damper in the carb - just a simple brass screw in cap with a screwdriver slot (not knurled). Question is should there be a spring or a damper. It has an electric fuel pump but the float in the bowl works fine as after a couple of clicks the pump stops prior to starting. Any answers as to spring and damper much appreciated.
Thanks for the advice. Things are looking much better now - car runs and does not cut out. It now starts without any choke and have the feeling it is still an over rich mixture but much improved. Have tried screwing up the mixture nut but with little change. I am unsure if the needle valve in the float chamber should be adjusted ie is the level there too high? There is no spring on the piston and the piston drops quickly when the throttle is released. Should the dashpot have oil? So a couple of issues still, but feel I am getting close.
