It's Sunday and I'm bored... - Printable Version +- Austinsevenfriends (https://www.austinsevenfriends.co.uk/forum) +-- Forum: Austin Seven Friends Forum (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=1) +--- Forum: Forum chat... (https://www.austinsevenfriends.co.uk/forum/forumdisplay.php?fid=14) +--- Thread: It's Sunday and I'm bored... (/showthread.php?tid=1879) |
RE: It's Sunday and I'm bored... - Bob Culver - 16-10-2018 Extracting many reliable miles just by applying own skills and little money to parts abandoned by others is very satisfying, if not as necessary as years ago. One item I add is a light spring to take lost motion out of the advance linkage. looks primitive but effective.. RE: It's Sunday and I'm bored... - Ruairidh Dunford - 16-10-2018 (16-10-2018, 12:47 AM)squeak Wrote: pleased to see the anniversary gold rosettes are surviving. We were privileged to drive this in Guildtown, I was secretly appalled at the sounds of wear and tear Not that secret Russell - your face told all! Can’t quite bring myself to remove the rossettes, was a good do and I am glad you are both there. RE: It's Sunday and I'm bored... - Reckless Rat - 16-10-2018 It's still raining here and I'm still bored... For as many years as I've had my RP the fuel gauge has never worked. It constantly shows 2 gallons but there's no power to it. Like Ruairidh I use a substitute, which is probably just as reliable. In my case it's not a stick, but a metal rod with graduations relative to the tank's contents. In the case of the RP with rear tank the graduations are 1"5/16ths apart for each gallon remaining. The rod sits quite happily in the driver's door map pocket, being readily available and easy to use. As a Yorkshireman I always like a belt & braces approach to things so I always carry a spare gallon just in case - the odometer doesn't work either. |
