08-05-2025, 05:16 PM
Best of luck!
Warning [2] Undefined variable $search_thread - Line: 60 - File: showthread.php(1617) : eval()'d code PHP 8.5.6 (Linux)
Getting Rear Axle back in
Best of luck!
10-05-2025, 08:13 PM
Hi
Final bit of advice…. Fit two nuts to the end of the spring pin and tighten them hard together. Firstly that gives less chance of damaging the threads when you get inadvertently aggressive hammering the pin in…..Secondly once in, you can twist the pin using a spanner on the nuts to help jiggle the cotter to fit. Also remember the cotter goes in from the rear, nut to front! Cheers Howard |
