Warning [2] Undefined variable $search_thread - Line: 60 - File: showthread.php(1617) : eval()'d code PHP 8.5.6 (Linux)
Nippy Chassis Questions
Hi Everyone
Sorry I forgot to ask about this hole in the back cross member, close to the exhaust bracket mounting holes. I've seen it on a couple of other chassis' but I'm not sure if it is original. If it is what was its purpose?
Thanks
If you look at the pic I posted earlier you will see the same hole in my cross member. Sorry no ideas what its for.
Hi
Thanks, yes I had spotted it on your car as well. It must be original, it is a bit of a mystery though because I don't think it is wiring or fuel pipe related.
Thanks again
Matthew
