Hi
I am amazed at the speed of your progress !
Thankfully, you seem to have got to things in time and no serious corrosion has been allowed to develop.
Don't forget to take a look inside the steering box.
Car type: No A7 yet!
Not to worry Bob, no children were harmed in the making of this post! With twin girls, even once we've given the better stuff away to friends and charity, there's a seemingly endless supply of clothes they've grown out of to use as rags!
Thanks Ivor, yes, theres always a mixed bag of folks out there. Thankfully, whilst inconvenient, I've not found any repairable damage yet!
Duly noted Howard, I went out and checked last night and I can see that the problematic hub already draws on a little further than the good hub, so I've ordered some Loctite 660 and will build up rather than grind away!
Thanks John, taking things apart is the quick easy bit, it's making them right and putting them back together than takes time! haha. I'm aware the steering box needs dealing with sooner rather than later, but if I take any more things apart before I start putting bits back together I'm sure to start loosing track of what everything is and where it goes!
