17-12-2021, 12:46 PM
What is the thread tapped into the block for the studs that hold the side water manifold?
BSF or Whit?
Thanks
BSF or Whit?
Thanks
| The following warnings occurred: | ||||||||||||
Warning [2] Undefined variable $search_thread - Line: 60 - File: showthread.php(1617) : eval()'d code PHP 8.5.1 (Linux)
Side water manifold studs
BSF or Whit? Thanks
I think from memory it’s BSF.
NEXT TIME IN THE GARAGE I WILL CONFIRM Yes I can confirm it’s 5/16” BSF NOT sure if all engines the same. That’s a 3 bearing Ruby
17-12-2021, 01:34 PM
17-12-2021, 04:03 PM
Thanks
