06-04-2021, 10:11 PM
anything out there sitting on a shelf, useable and with a still-reasonable compression ratio?
Running fine with '37 head but water is presently going round the houses to get to scuttle header tank.
An alternative would be a home-converted HC outlet to go toward bulkhead if anyone has mucked around with same issue in past.
