Sports Rear Springs
Try again.
I have a pair of Sports rear springs surplus to requirements. I bought them from Iain Dunford over 20 years ago but decided to use Ruby springs with a leaf removed for my Speedy (which Nick Turley had found gave a better ride height on his Speedy). They have six leaves of approx. 8mm thickness and are flat as you can see in the photos.
Offers around £325.
Hi Martin,
unless you specifically requested completely flat rear springs at the time, we did not supply these. Our sports rear springs have 2 1/2" camber as per factory spec.
If we did supply them, they will have been produced completely flat as a specific request from you. Flat springs are not normally suitable for road going cars.
Hope that helps,
Ruairidh
Hi Ruairidh,
Interesting, as far as I remember, when I bought them, probably about 1992, I only ordered Sports springs - nothing special. Maybe that's why Nick suggested using Ruby springs with a leaf removed? Anyway it's all in the dim & distant past, so hopefully someone will have a use for them.
Martin
