Would some kind soul be able to take some windscreen measurements for me please.
I would like to know the size of the of the steel side iron section for the screen, preferably measured with a micrometer.
Also the dimensions of the lower screen channel and the thickness of the glass.
Finally maybe a photo of the lower screen corner.
I suggest that all these measurements "in the day" would have been to the nearest sixteenth or thirty second part of an inch....
David
Thanks for the photos Tony. What year of car is it?
Any measurements for the bottom half of the screen sections would be greatly appreciated.
I think the glass was 1/4" plate glass or triplex laminated if you paid extra. The laminated became a compulsory retrofit sometime in the early 'thirties I believe.
Thanks for the information Tony,
Looks like the screen channel is a nominal ½"x⅝". Now where to source some?
Can your friend give us the other dimension for the side iron please?
Thanks Tony,
I didn't realise that you have two chummies including your schizophrenic friend.
Does anyone know of a supplier for the ½"x⅝" brass section?
