03-12-2020, 09:37 PM
If by fauslt or mistake chanced to be connetced direct to battery more available.
changing rheostat type on fuel sender?
04-12-2020, 10:34 AM
Modern cars typically have the fuel pump within the fuel tank with no problems.
Petrol is reluctant to burn unless the air/fuel ratio is about 15:1 by weight. Inside the tank the vapour is saturated which is safe.
04-12-2020, 11:35 AM
You are both right of course.
But the mini configuration still frightens me... |
