That's what I always loved about this forum, quick and informed advice! So, they're all like that - at least I can keep the carrier. My distance piece is also 5/8". I've measured the ball bearings and they are also correct. The pinion shaft is 22 3/16" total length. So...unless I have a torque tube that is longer than it should be (is that possible?), it is all correct, and I should probably just tighten everything down and stop worrying. Fair conclusion?
Many thanks!
Geoffrey
Hardly dare mention but presumably the a/c races are assembeled with the outer rings abutting?
Were stepped rings an Austin special or were most a/c races so finished to help guard against wrong assembly?
You're quite right to ask - all suggestions welcome. I put the two faces marked 'thrust' together, so the inner races have to be squeezed together to meet. Correct?
10-06-2020, 02:11 AM
(This post was last modified: 10-06-2020, 02:12 AM by Tony Press.)
As far as I know only Austins used the narrow outer ring Angular Contact bearings.
That seems correct- if the wrong way around the outer rings would be separated.
Hi Stuart, is there any problem with replacing the ball bearing next to the pinion with a roller bearing.
The ball bearing in that location always seemed to me to be a candidate for improvement.
Rgds Gene
It is true the pinion ball races did not last forever and were later dropped. Roller races also facilitate mesh checking. But bearing ratings (reputable brands!) are much increased since the 1930s and a ball race less expensive. Few cars are going to do another 100,000. For those with lathes and adept at use of fitting a precision concentric sleeve finished within .0002 is not difficult, but it is for many.
Do a check measurement of the pinion end six bolt flange to match against the crownwheel position to see if the pinion insertion is correct.
you can also seperate the axle half and insert the pinion to have a visual idea of insertion meshing.
