Engine numbers
Hi Can anyone please tell me the year and info on engine number M256468.
According to Wyatt it around the end of October 1936
Further note, it should be a three bearing engine given the date
It is probably a 3 bearing engine, from around October 1936.
If so, there should be the head of a bolt high up on the crankcase side, half way along, just below the tappet cover.
It may have been modified the take a 2 bearing crank, though.   I don't know if this can be checked by looking down the oil filler tube.
If 3 bearing, and the engine came from, or is still in a car that hasn't run for years and years, the crank is probably broken.
They will often turn over on the handle, even with a broken crank.
If it has obviously been looked after, then a good three bearing engine is a much smoother driving experience.
Simon
Thanks guys Shy
