14-01-2020, 08:20 PM
Good evening,
I am after a passenger side window for a 1931 LWB seven please.
Kind regards,
Mike
Kind regards,
Mike
1931 RN box saloon door glass
Good evening,
I am after a passenger side window for a 1931 LWB seven please. Kind regards, Mike
17-01-2020, 01:50 PM
The simplest solution is to get a new glass cut. If you have a good (usually independant) glazier locally they will be able to cut one to size in 6.4mm laminated glass, or order one in 5mm toughened. Ask them to bevel all edges. New metalwork, if needed is available from Oxfordshire Sevens and probably other suppliers. too.
