Stephen I have never taken the groove to the edge and that's on a race/sprint crank but make sure you have 10 to 12 thou side clearance and the gudgeon pin sits central in the piston when viewed from below. Terry.
15-09-2019, 08:02 PM
(This post was last modified: 15-09-2019, 08:09 PM by Bob Culver.)
Not sure if it lets oil in or out. From dirt grooves suspects a lot comes in. Often see them just drilled but not sure if ever this way originally. Based on the observation of pattern on bearing and book attitude to grooves under load I ran mine with no holes but altho not a racer suspect a mistake. Austin presumably had a reason.
Some sort of shallow relief at the parting line as original seems desirable/necessary. Dont think this ran to edge.
My current thought is to make this groove the same length as the chamfer on the edge of the separation face.
We have had just one really authoritative response based on racing experience so reliable.
But what do regular rebuilders do? Do the later shells have grooves? Are these cut in shells for racing? How common are simple drillings? Were these ever the original, and any problems attributable? Transverse grooves in loaded areas are agin all theory, and in accord with this the wear pattern usually looks inferior on the leading edge, but this may be due to dirt entering.
HI Steve,
Your thinking is right , only I would Block off the two holes in the rod end and only put the groove in the Cap but as you say Not right to the Edge
the Reasoning behind this is the load is on the rod and not the cap and the oil will flow out both sides of the rod this gives a solid oil film on the rod half
this is not a theory but from casting and machining a lot of rods and main bearings
Hope it helps
Colin
NZ
HI Steve,
If you think about it the two holes throw oil out sideways so it would hit the oil plate between the crankcase and block,
the last thing you need is losing pressure on the loaded side of the bearing.
something to think about.
Colin
NZ
18-09-2019, 08:54 AM
(This post was last modified: 18-09-2019, 09:11 AM by Bob Culver.)
Trenches in high loaded areas, ie top or bottom are generally to be avoided.
The Seven with its curious lube system is different. The oil spray is everywhere and I suspect quite a lot is slammed into the drillings on the upstroke. At the top of stroke oil would exit and serve to briefly vent oil and air from the main entries on the crank.
Did the 3brg shell cars retain the rod drillings? Was the shell trenched?
(Incidentally blocking the holes did not seem to reduce oil consumption on my car)
