26-03-2019, 08:40 AM
Yep, completely normal. Doesn't need greasing often.
Steering box oil leak
26-03-2019, 06:55 PM
Hi Adrian
I recently overhauled my steering box, although I hadn't previously had a problem with oil travel up through the column, I fitted an "O ring" over the inner column which made a seal between the two, thus preventing oil rising even if the box was over full.
26-03-2019, 08:36 PM
When I overhaul a steering box I fill it with MoS2 grease and then that's it, greased for life. The RN with over 80,000 miles hasn't been touched and is still silky smooth.
