10-02-2020, 12:39 AM
Most impressive! I too would love to see it in the flesh, please keep us informed of your planned attendances at events.
Slippery Anne update
10-02-2020, 01:15 AM
An excellent re-creation of a famous car
One area of the car is causing pause for thought, I am unsure of which oil to use in the 1923 back diff/axel, the mixture of oil and grease recommended in the old lubricating charts sound 'interesting', From memory the original differential lube was a mixture of 'engine oil and yellow grease'- yellow grease has long gone, replaced by Lithium grease- not sure how this mixes with SAE 30. Your suggestion of D 140 sounds good (non sulphur phosphorous)
10-02-2020, 02:43 AM
Looks great. How can we find you on Instagram?
10-02-2020, 01:44 PM
(This post was last modified: 10-02-2020, 01:45 PM by David Stepney.)
I would suggest using SAE 140. Although the rear axle on my RP does not get anything like the stress of a racing axle, Using SAE140 has quietened it down no end. Modern oils are also far superior to anything that would have been available almost a century ago.
Absolutely stunning car, by the way!
17-02-2020, 12:35 AM
Fantastic work Mark! A real inspiration, well done.
17-02-2020, 06:27 AM
Superb work Mark. It would be great to see her in the flesh....perhaps you can keep us updated when you plan to compete in her.
19-02-2020, 12:25 AM
(This post was last modified: 19-02-2020, 12:29 AM by Mark Atkinson.)
Hi Duncan,
I am entered for all this years VSCC Sprints and Hill Climbs, of course actually turning up with the car is dependent on making her fit to run, I will keep you posted! Regards, Mark Please look for markgeorge1210. Regards, Mark
19-02-2020, 08:04 AM
Hi Mark,
Hats off to you! Superb. Can you tell us a bit more about how you attached the linen so taughtly and what 'dope' you will use. Paul N-M
19-02-2020, 09:00 AM
Would that include Harewood Hill climb?I hope so, as it's on my doorstep.
19-02-2020, 12:10 PM
(This post was last modified: 19-02-2020, 12:12 PM by Steve Jones.)
