Warning [2] Undefined variable $search_thread - Line: 60 - File: showthread.php(1617) : eval()'d code PHP 8.5.6 (Linux)
NGK spark plugs
The spark plugs I changed today were NGK6. I was about to replace with some labelled NGK7 but wasn't sure if they were ok as the number was different. I played safe and replaced with a new set of NGK6 but just wondered if I can use the NGK7 in a 1934 box saloon or would they be wrong. I'm not sure where they came from but I've been carrying them around under the back seat for years! Thanks Richard
The 7 is a cooler running plug so may oil up, however would be a good spare. This site gives some interesting info http://www.briskusa.com/spark_plug_cross...ange_chart
