Warning [2] Undefined variable $search_thread - Line: 60 - File: showthread.php(1617) : eval()'d code PHP 8.5.6 (Linux)
  • 31 Vote(s) - 3.16 Average
Hi Peter,
Bill Sheehan in 2010 confirmed his advice:
Long Wheelbase High Frame max 6 1/2"
Low Frame max 3 1/2"
The crank handle should sit to the left from the front (opposite to yours) sitting on a support in the tunnel.
Cheers, Tony, Melbourne.
Thanks Tony.
Hi Peter,
I like the look of your tourer. The cut-down doors makes it look less chunky than an Opal or a Pearl. Is it made from a Pearl or a Ruby?
Graham
I would think the Austin 7 tourer body would be Australian made on an imported chassis as was the practice then.
Tony is spot on.
Cutaway door style rather typical of Holden bodies?
Maybe a bit late for Holden- often they had an aluminium id label under the rear seat.
I think most Australian bodied late tourers had the cutaway doors.
Cheers,  Tony
Yesterday, we turfed the Seven out of the garage so that we could work on Leon's Morris Minor. Whilst he was cleaning up the floorpan and assessing just how much welding is required, I used the Seven to go out and do a bit of essential running around.
Car outside a friend's at Llanuwchlyn
View of the lake
Another view of the lake and it's bleakness.
The church at Llangower
The old bridge at the top end of the lake where the River Dee used to start.
Ah a much used Seven.
Have you bought a new camera, David?
Users browsing this thread: 1 Invisible User(s), 32 Guest(s)
