18-06-2018, 12:13 PM
John, I believe you are correct and it is 1.5mm, you could solder up a 2mm one and re drill to the correct size.
Zenith 24T2
18-06-2018, 08:41 PM
29-10-2018, 07:37 PM
Colin - do you by any chance have the bit of the table that has the C.1372 Austin 7 variant on it?
I note its not in either of the ones above...
29-10-2018, 08:49 PM
(This post was last modified: 29-10-2018, 09:04 PM by Colin Morgan.)
Hi
Not found a table. However, the Dorset Austin Seven Club site quotes the following from an article (attributed to Tim Reynolds) on the 24T2, C.1372 that gives: 'The settings are as follows: Choke tube 14 Main Jet 75 Slow Running jet 50 Air Cap 150 Needle valve 1.5' Hope this helps. Regards, Colin |
