Durability replica cozette
Hello
How long do the plastic wings last in a repro Cozette blower?
How do I realize that they need to be changed?
Thanks and Greetings
Thomas
PS: I'm still looking for the correct ignition timing
Hi Thomas
The vanes should last a long while providing your supercharger is fed with clean filtered air with enough oil in the fuel to lubricate them.
Having your car set up on a rolling road dyno would determine the ideal ignition timing and possibly carburettor settings.
A fitted boost gauge will give you an idea of what is going on if performance drops
