Nippy lighting set 1936 - on
I have available a lighting set for a Nippy 1936 on. It comprises a pair of L131/133 refurbished headlamps replated with dipping projector bulbs. A pair of nos Lucas LD109 sidelights and a nos ST38 pork pie lamp.
Cost is £550 to include p+p to UK.
This looks interesting.  My car is 1934 but the headlights are not correct so this may be a step in the right direction.  Do you have pictures you can send?
Thanks
Steven
Thanks for the reply. Could you send me an email to stuart.joseph@btinternet.com as I have problems downloading photos to this site.
Your 1934 lamps should be Lucas LB130’s which are identical in function to my later lamps (same glasses etc) the bowls/shells are a little different. The sidelights are identical as is the ST38 ‘pork pie’ rear lamp.
